Machine Vision
Problem multi-thread CVI program & NI Vision Custom Controls
I have a problem with Custom Controls in a multi-thread CVI program.
Here's what I do: Thread 2 opens a connection to a GigE Camera, creates a Custom Control and displays a live video from now on. Thread 1 handles all the rest. Whenever there are a larger number of user events (clicking buttons or moving the program window) the Custom Control freezes and the program crashes.
As the Custom Control functions are non-thread-safe I made sure that thread 2 uses ImageControl_ functions only. However NI Vision and NI IMAQdx create addition threads that might cause a problem.
I've attached a small program that demonstrates this effect. Click "Start Test" to create a Custom Control and show a live video. Normally the program won't crash at this point. Press "Enable Timer" to enable a timer that ticks 10 times per second and resize or move the program window. These additional events will cause a program crash.
Does anybody of you know this effect?
mju_
(5,189 Views)
I think we need to separate the processing and display.
For exemple you can use an Timer to display image and use Thread to processing
Good day
(5,165 Views)
maybe I haven't got the point yet but how does the timer help? As the custom control routines are non-thread-safe, the timer callback will have to run in the second thread as well, so there is no real change...?
_mju
(5,141 Views)
Hi mju,
I haven't looked at your code but if I understand your description you are interacting with a user interface control from a thread other than the main thread, This is generally not allowed on Windows (or any platform for that matter). Even if you restrict you usage of it to a single thread, any interaction with the OS (UI events, etc) all come in via the main thread and so will potentially collide.
Eric
(5,127 Views)
Eric,
tank you for your reply.
I thought that I'm allowed to work on controls from (nearly) every thread. In the helpfiles I found a page (Panels and Multithreating). It says:
If you create a child panel, you must do so in the same thread in which you create or load the top-level panel. You can create controls other than timer controls in any thread.
However, my problems seems to indicate that this is not completely true for Custom Controls...
mju
(5,094 Views)
