Machine Vision
Problem using NI PCIe-1437 frame grabber with EDT VisionLink RCX Camera Link Fiber Extender
Attempted to collect data with an NI PCIe-1437 Camera Link frame grabber in 14-bit base mode using a EDT RCX VisionLink Camera Link fiber extender pods.   First got the system working using a standard copper cable.   Then replaced the copper cable with the fiber optic pods, using 1 meter MDR-SDR M/F camera link cable at the ends.   The fiber receiver at the frame grabber end was operating at the max 85MHz clock frequency.   The acquisition software grabbed one frame (that looked ok) and then timed out waiting for subsequent frames.   When we tried the same setup (camera, cables, fiber pods, fiber, PC, application software), but changed out the NI PCIe-1437 for an older NI PCIe-1433 card, the system worked.    Any ideas on why the 1437 card had a problem, and more importantly how to get it working?
(2,571 Views)
Did you figure out the cause of this issue?  I have a similar problem where the 1433 works fine, but the 1437 is having an issue when the imaging is interrupted and resumes.
(720 Views)
