Machine Vision
Problem with Photonfocus camera
I have a Photonfocus camera MV1 (agmv0-d2048x1088-c01-hs02-160-g2). I have downloaded all the latest drivers for the camera necessary to make it run but when I try to take an image its just a black screen. The result is the same in both NI-MAX and in Labview. I don't know what could be the issue. The only thing that comes to mind is that I'm running Labview 2023 Q3 and I don't know if it supports Photonfocus cameras, but I couldn't find anything that would suggest that it doesn't. If anyone has experience with this or has a suggestion I would gladly welcome some advice.
Message 1 of 1
(767 Views)
