Machine Vision
Problem with ROI rotated rectangle
I have a ROI rotated rectangle with LEFT TOP coordinates and the rotation angle fixed. i am looking to put in the ROI input and change the RIGHT of different length as the image I attached ( image 1).
I tried using the IMAQ Convert ROI to Rectangle function and changed the short length of RIGHT (image 2) but it ran out of my expectations, It is deviated from the original ROI position and the length is also wrong when I enter the RIGHT value of half or 3/2 of the original value.
Can anyone help me how the rotated rectangle ROI works and how to solve the above problem.
Thank all
(3,512 Views)
Accepted by topic author Vu_Anh
You have to modify ROI.  You can use "IMAQ transform ROI" function to change the rotation center from the center of rectangle to left top point of rectangle.
(3,463 Views)
You can revert labview 2019 to 2018 ? Thank you your comment
(3,452 Views)
The attachment has been saved for LV2018.
(3,449 Views)
Thank you very much. Change the rotation center from the center of rectangle to left top point of rectangle is the crux of this problem. It really works
(3,445 Views)
