Machine Vision
Problem with Shared Variable - Network Published
i want to use a Shared Var at my NI Compact Vision 1455 - Network Published!!
i downloaded the vis with the shared var to the cision and got the following error:
Deploying CompactVision  (successfully deployed target settings)
Deploying IMAQ Create  (already deployed)
Deploying IMAQ1394 Start Acquisition.vi  (already deployed)
Deploying IMAQ1394 Wait For Occurrence.vi  (already deployed)
Deploying Inspect Format Parameters.vi  (already deployed)
Deploying IMAQ Overlay ROI  (already deployed)
Deploying IMAQ ROIToMask  (already deployed)
Deploying IMAQ Image Cluster to Image Datatype.vi  (already deployed)
Deploying IMAQ ColorHistogram  (already deployed)
Deploying IMAQ1394 Configure Acquisition.vi  (already deployed)
Deploying IVB Decision Maker (Float).vi  (already deployed)
Deploying Imaq GetImageInfo  (already deployed)
Deploying IVB CoordSys Manager.vi  (already deployed)
Deploying IMAQ1394 Init.vi  (already deployed)
Deploying IMAQ Overlay Text  (already deployed)
Deploying IVB Results Manager.vi  (already deployed)
Deploying IMAQ1394 Stop Acquisition.vi  (already deployed)
Deploying ni_tagger_lv_ConnectBuffered.vi Failed to download ni_tagger_lv_ConnectBuffered.viLabVIEW:  Failed to load shared library nitaglv.dll:ni_tagger_lv_ConnectBuffered:E on RT target device.
Download completed with errors.
any idea how to solve it?
greets
(4,067 Views)
Surfman,
have you checked that the following packages are installed on the target:
-Shared Variable Engine 1.0 (for hosting i/o servers)
-Variable Client Support 1.0 (to access network-published variables)
Another problem could be the names of your shared variables. Make sure that no blanks are included.
ThSa
(4,031 Views)
I have got some problems with SV when deploying.
The only solutions i found was to format my target hard drive and to reinstall it. It takes no more than 10 min and it solved my deploying problems.
(3,931 Views)
