Machine Vision
Problem with Vision Builder 3.5
I'm using vision builder 3.5 for product inspection. I kept my program in startup menu so that I can open Inspection Interface Screen as default. And as soon as the screen opens the inspection should be in running mode. Because the system will be stand alone, only the monitor & CPU will be provided on the line.
            But now my problem is I'm not able to shutdown my system... 😞 Is there any method to solve this problem using vision builder...?
Thanks in advance.. 🙂
Message 1 of 9
(4,997 Views)
You can do that using VI server. Search ni.com to know more about VI server.
Message 2 of 9
(4,957 Views)
This can be of help to you.
http://zone.ni.com/reference/en-XX/help/371361A-01/lvhowto/vi_server/
Message 3 of 9
(4,955 Views)
Hello...:) Thanks for reply... 🙂 But I don't want to close any VI... I want to shut down my computer using Vision Builder... Is it possible with VI server because it is built in LabVIEW...?
Message 4 of 9
(4,932 Views)
Hi
have a look at this:
http://digital.ni.com/public.nsf/allkb/77390BF1B5B34714862569830062E68E?OpenDocument
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
Message 5 of 9
(4,906 Views)
Hello... 🙂 Thanks for the reply Vaibhav... 🙂
That does work for logging off... But it's giving error in shutting down... Can you help...?
Message 6 of 9
(4,893 Views)
Hi Rupali,
It should work, i dunno why its not working.
try out these two links:
http://zone.ni.com/devzone/cda/epd/p/id/3057
http://zone.ni.com/devzone/cda/epd/p/id/2556
I hope this works.
Regards
Vaibhav Singh
btw u can search for your queries on www.ni.com and click on NI developers zone.
...//____//......
..//____//......
.//____//......
Message 7 of 9
(4,863 Views)
Hello Vaibhav... 🙂
It's working fine.... Now I have to link it with vision builder.... So that after inspection of products computer will shutdown automatically... 🙂
Message 8 of 9
(4,850 Views)
Hello... 🙂
               Can anyone please tell me how to fix the size of picture in inspection mode... I mean whenever I start the inspection the picture shown is in 1:1 form I want to minimize it from the start of the inspection... Is it possible... ? Please reply... Thanks in advance... 🙂
Message 9 of 9
(4,745 Views)
