Machine Vision
Problem with pixel clock for 1409 and linescan camera.
I am having difficulty getting the 1409 to lock onto a video signal from a linescan camera. I have provided H-Sync (30KHz) and V-Sync (59Hz), however, the External HV Lock mode does not work. Additionally, is there any documentation describing the camera attributes for a linescan camera? Specifically, why must I specify freqencies for the external clock and external line sync when they are externally supplied?
(2,930 Views)
David,
I believe How Do I Use Analog Line Scan Cameras with NI-IMAQ? should answer your questions.
As the document mentions, these setting are available to send to a camera that requires them.
Please let me know if you still have questions.
Amaury
NI Applications Engineer
(2,930 Views)
