Machine Vision
Problem with "AVI Read Write Example"
I'm using "AVI Read Write Example" to get image from a AVI file.When I analyze the image I have this message of error:IMAQ Histograph Invalid image type. What is the problem? Thanks a lot
(3,258 Views)
That error will come up anytime you use the IMAQ Histograph.vi with an input image type other than 8bits, 16bits, or Floating (as these are the only supported types for the histograph function). Make sure your input is one of the supported image types.
Hope this helps!
Yusuf C.
Applications Engineering
(3,258 Views)
