Machine Vision
Processing variable gray image
I'm surprized by the scores you get with Vision assistant :
On my PC (Athlon 2.6 GHz, 512 ko RAM, W2000K) I find :
- Conveyor belt : 160 ms/image
- Conveyor belt 2 : 275 ms/image
Quite far from your scores ! May be instead of trying to improve the algorithm, you should try to improve the PC !
Chilly Charly    (aka CC)
Message 11 of 15
(1,639 Views)
Hum, I made a "small" mistake. I made some confusion between scripts :
conveyor belt
Message 12 of 15
(1,633 Views)
- conveyor belt         56 ms/image
- conveyor belt 2    160 ms/image
Any comment ?
Message Edited by chilly charly on 07-29-2005 04:38 AM
Message 13 of 15
(1,634 Views)
HI CC
I’m sorry ,I believe I overloaded your mind, with my overextend and boring 9 points post!
All images I sent you were 355x355 pixels and 640x480 pixels. I'm talking about whole inspection area.
Read again, please, my item 8
8] And YES you are right, I’m afraid too. Now, I enlarged an image to a final size of 680 x 745 pixels
within an inspection area of 1250x960 pixels.
Voila cést tout ce qu'il y a de mystere:  I’m scoring an image four to ten times bigger!!!
In my PC, scoring 355x355 pixels images: CBelt=50ms/image and CBelt2=143ms/image
Yet, I need to stop many time consuming process running on XP, to improve score. And I read some
comments about best real time performance on W2000 over XP.
That’s correct?
Can you do any work with my last posted high contrast images?
Best Regards.
Message 14 of 15
(1,626 Views)
Of course, playing with better contrasted images is a pleasure. I have attached 2 new scripts.
Conveyor belt High contrast should be close to optimal for shape, and is slightly faster than the previous script. I used manual thresholding, but in case of variable light level, it could be necessary to use an automatic thresholding procedure, searching for a minimum in the grey level histogram, between the object and the background.
Conveyor belt High contrast High speed does the job in less than 2 ms/image !
Of course some compromise could be found between these two extremes solutions.
I also think that with such well contrasted images, the direct pattern matching could work without preprocessing.
Message Edited by chilly charly on 07-30-2005 03:52 AM
Message 15 of 15
(1,613 Views)
