Machine Vision
Pulnix TM-1040 asynchronous reset
I have an IMAQ PCI 1422 card connected to a Pulnix TM-1040 camera through a NI D-10031 cable. I also have the IMAQ 2504 cable for triggering. I would like to send an asynchronous reset to the camera via an analog trigger line. However, I can't find any information about how the D-10031 is wired. Does somebody knows if one trigger line of the 2504 cable is connected to the VINIT input of the camera ? Thanks in advance.
(3,351 Views)
I was able to trigger the camera by using the High Level Trigger VI posted somewhere on this site. However, when the camera is in asynchronous mode, I get a timout error 50% of the time. Any idea??
(3,351 Views)
The IMAQ 2504 Manual describes how to attach the IMAQ 2504 cable to your image acquisition (IMAQ) device.
Use the IMAQ D2504 cable to connect four external trigger sources to your IMAQ digital device via the IMAQ D100 camera cable.
Good luck with your application and have a great day!
Koninika
http://www.ni.com/support
(3,351 Views)
