Machine Vision
Question for the IMAQ learn camera model vi
Dear experts.
I have one quick and short question. I'm using the IMAQ learn camera model.vi. What does mean by "image" input line?
I guess camera calibration results will be saved in the "Calibration Template Image" and the only information for camera calibration is "Reference Points". Is it right?
However, I'm not sure what is the "image" input?
(4,689 Views)
Hello chulminy,
the "input image" is the image of the calibration grid. This is the same image, from where the "reference points" needed for calibration are extracted. At least, that is the input I am using.
It is also possible to leave this input unwired, the calibration will still be performed.
Take a look at the "Perspective calibration example.vi". The "IMAQ Learn distortion model" is used basically the same as "IMAQ Learn camera model". (the camera model learns the optical characteristics also - principal point and focal length).
Hope this helps.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(4,678 Views)
Hi K,
there must be a reason for the input of "image", I assume the image input will be used to fine tune the results, but need NI developers to confirm.
Regards
T
(3,633 Views)
@HighTech wrote:
Hi K,
Regards
T
looking at the function call, I see that the "image" input is declared as a "void *Thumbnail Image". Judging by the name, this is a reduced image of the original, though I don't know what is the purpose of it. Probably to recognize the image easier if you store it on a HDD.
If you find out anything further about this, please post it here.
K
(3,615 Views)
