Machine Vision
RBG from camera and convert it to CIE tristimulus
Hi, but these values do no correspond to the ones when I try here http://www.easyrgb.com/index.php?X=CALC#Result
Message 11 of 12
(801 Views)
"Please check the XYZ white reference parameter, by default it uses the XYZ values of a standard D65 illuminant (6500°K)."
Any other option for reference parameter ? when i use default reference , the output if XYZ alway show lower than ~1.2.
But seems like the XYZ should be between 0  and 150 , right ? Do you have any idea that how make this happen , need to choose what
kind of  reference parameter?
Message 12 of 12
(774 Views)
