Machine Vision
RGB float image for deep learning
I would like to classify two objects using mobilenet (input shape 224x224x3). I have trained the model in Keras and converted to .pb format. To make the training process easier, I preprocessed the input RGB image pixel value to [-1..1] range. However, I was not able to create a RGB float image in labview to input to the network. Is there a way to create this kind of image for Labview's DL Model Set Input.vi?
By the way, what is the proper way of creating a array for Labview's DL Model Set Input.vi? I tried, but the result was not as expected.
(3,079 Views)
Accepted by topic author tomsze
I have found the solution of usng array as input.
Labview 4D array is slightly different from python numpy 4D array so it needs to be rearranged.
Labview array for DLLabview array for DL
(2,852 Views)
