Machine Vision
ROI in Motion Detection
Hi all!!
It's possible apply a ROI function on the motion detection alg (http://decibel.ni.com/content/docs/DOC-4717) to detecting movement ONLY in a specified area?? Thank You very mutch!
(5,830 Views)
Sure. Just use IMAQ ROItoMask and then IMAQ Mask before (or after) calculation of Absolute Difference.
Andrey.
(5,820 Views)
Can you attach an VI example of this??
(5,626 Views)
Something like that:
result (take a note that my camera deliver RGB image, so the original example is slightly modified):
VI in attachment.
Andrey.
(5,618 Views)
Thanks a lot but i have a version 8.5 of lab and i can't open your file 😞
I can try to apply the IMAQ mask on my Vi but the recognize system not work only in a specific area...
I attach here my modiefied version of Motion dection (my version can register on avi file), can you modify my version to apply roi?? i'm desperate!! 😞
Thanks a lot for you time!
Bye
(5,601 Views)
I Have solved!!
Thank You!!
(5,553 Views)
