Machine Vision
ROTATE ARRAY
HELLO!
How can I rotate and array? I don't want to rotate columns, I want to rotate rows.
0
1
2
3
4
to
4
3
2
1
0
thanks!
(3,560 Views)
Since you are posting in the vision board, i suppose that you are working with images.
If you have IMAQ vision tools, use the IMAQ Symmetry vi (vision>vision utilities>image manipulation>IMAQ symmetry...).
Otherwise, you'll have to use an autoindexing For loop, and a reverse 1D array, as shown in the attached vi.
CC
Chilly Charly    (aka CC)
(3,555 Views)
Sorry, I attached the wrong vi. Here is a better example.
(3,552 Views)
