Machine Vision
Raytheon 2000b camera with PCI-1422
I am trying to use a Raytheon 2000b camera with PCI-1422. I have downloaded the attached doc and icd file from NI.
1. As far as I now there is no proper NI cable for my camera, but the pinout is described in the doc file. I would like to purchase a cable, and solder a connector on it for my camera. Which cable should I choose, if I need the following pins on the PCI-1422 side: 1-32, 41-46, 49-50, 93-94, 99-100?
2. The icd file supports image acquisition only, attribute settings via serial line are not contained. I would like to add this feature, but I could not find any description about the icd files. Where can I find a document that would help me?
Message 1 of 1
(3,237 Views)
