Machine Vision
Read avi files not created in labVIEW per frame
Hi everyone,
I want to read an .avi file not created in labview per frame. (see attached picture for .vi and error code)
Is is possible to read the frames?
(5,049 Views)
Hi Henk_kempen,
I have been able to find another forum post which addresses this issue:
http://forums.ni.com/t5/Machine-Vision/problem-using-quot-open-AVI-quot-on-ffdshow-encoded-avi-files...
Try the workaround described in this forum.
Please post back with an update!
James V.
NI UK Applications Engineer
(4,989 Views)
Thank you very much for your fast response, I'll check the other topic next monday!
(4,979 Views)
I don't get it, do I have to download ffdshow (I don't know anything about codecs)? How does that program work, is there an easier way to read the frames? I found a way, thank you for your help
(4,945 Views)
