Machine Vision
Read pixel size of camera
is it possible to read the pixel size of a camera programmatically with IMAQdx?
e.g. Basler ace acA1300-30um:
Pixel Size horizontal/vertical3.75 µm x 3.75 µm
Thanks in advance.
Thomas
(6,312 Views)
Accepted by topic author ts-s7rs
Hi Thomas,
The only way to read that programmatically would be if the vendor exposed this information as an attribute via their XML file. I looked at a couple of Basler aces that I have, and none of them seemed to have that information. They have an attribute called PixelSize, but that refers to bits per pixel and not the physical size. I skimmed the GenICam Standard Features Naming Convention to see if there is a standard GenICam feature for what you're looking for and didn't see one. Unfortunately it seems like you won't be able to get that information programmatically.
Katie
(6,301 Views)
Hallo Katie,
thank you for your quick response and investigation.
Instead I'll read the camera model name and define the pixel size for all possible cameras.
Best Regards,
Thomas
(6,298 Views)
pretty sure Basler ace does not have pixel size in um in camera attribute.  : )
(6,141 Views)
