Machine Vision
ReadFile in C# or Open with Bitmap object
I use Visual Studio 2005 in C#. My project is a library.
First
I'm a problem with the last param of ReadFile(CWIMAQIMAGE, Path, object ColorPalette)
in the docs, the last params is optional, but not in C#!!!
I have teste to put in to null, but I have a exception.
Second
I would like open my picture from a Bitmap object, but I'm not find any function to do this.
This is my class:
class NIVision
    private CWIMAQImages image;
    public NIVision(String path)
       ReadFile(image, path, null);
    public NIVision(Bitmap bmp)
       // I would like put bmp to image
   public Bitmap getResult()
       // I don't know to do this
       return image;
Can you help me to resolve these problems.
(6,843 Views)
I'm rewrite the library in VB.NET, but I'm the same error:
Nobody can help me?
Message Edité par lachinaj le 04-28-2008 06:51 AM
(6,813 Views)
lachinaj -
Sorry for the delayed response.
In C#, to pass a missing parameter to a function you have to use System.Type.Missing, not null.  So something like
axCWIMAQVision1.ReadFile(axCWIMAQViewer1.Image, @"c:\someimage.png", System.Type.Missing);
should work.
Unfortunately, there does not seem to be a direct way to load a bitmap into a CWIMAQImage.  You could copy the bitmap to the clipboard and use the CWIMAQVision.ReadImageFromClipboard() method to load it in an image, though.
Greg Stoll
Vision R&D
Greg Stoll
LabVIEW R&D
(6,799 Views)
I don't understand my error, if y use the AxCWIMAQVision and Viewer and if this object is focused all is ok.
But if its not focused I am this error:
Exception of type 'System.Windows.Forms.AxHost+InvalidActiveXStateException' was thrown.
This is what I want, it's possible to do?
NationalInstruments.CWIMAQControls.CWIMAQVision vision = new NationalInstruments.CWIMAQControls.CWIMAQVision();
NationalInstruments.CWIMAQControls.CWIMAQImage image = new NationalInstruments.CWIMAQControls.CWIMAQImage();
int ret = vision.ReadImage(Image, "source.jpg", System.Type.Missing);
vision.Threshold(Image, Image, 0, 255, false, 90);
vision.WriteImage(Image, "image.jpg", NationalInstruments.CWIMAQControls.CWIMAQFileFormats.cwimaqFileJPEG, System.Type.Missing);
(6,789 Views)
Nobody can help me?
(6,726 Views)
