07-08-2010 01:02 AM
Want to build an application with NI vision to receive the remote video data and play it. The video data is the CIF format and using TCP/IP to transport from the remote video server. If want to achieve the live play, should using which functions to do this? Thanks.
David
07-09-2010 02:14 AM
First, you have to extract the image data from the TCPIP frame as a 352x288 array of pixels. I believe that this will be your main problem.
Then you'll have to use the Pixel Manipulation >> IMAQArrayToImage function.
The image should be stretched to 384 pixels wide (Resample), since the pixels in a CIF image are not square (ratio 1.222 to 1).
Hope this helps
07-09-2010 03:26 AM
Thank you ,Chilly. I'll do my test .
David
