Machine Vision
Receive video data and play it
Want to build an application with NI vision to receive the remote video data and play it.  The video data is the CIF format and using TCP/IP to transport from the remote video server. If want to achieve the live play, should using which functions to do this? Thanks.
David
(3,219 Views)
First, you have to extract the image data from the TCPIP frame as a 352x288 array of pixels. I believe that this will be your main problem.
Then you'll have to use the Pixel Manipulation >> IMAQArrayToImage function.
The image should be stretched to 384 pixels wide (Resample), since the pixels in a CIF image are not square (ratio 1.222 to 1).
Hope this helps
Chilly Charly    (aka CC)
(3,201 Views)
Thank you ,Chilly. I'll do my test .
David
(3,198 Views)
