Machine Vision
Receiving Hsync and Vsync through RTSI connector in IMAQ(1410)
Hi
I'm using DAQ(6229) and IMAQ(1410).
The Hsync and Vsync is generating from DAQ(6229)
and I want to receive the Hsync and Vsync signal from DAQ to 1410 through RTSI connector.
Please kindly let me know that this is possible.
Seong.
Message 1 of 8
(5,029 Views)
Hi Screwball,
sampling rate of this card is good enough to sample and/or detect H sync and V sync.?
if yes then you can do that.
Alpesh Prajapati
Message 2 of 8
(4,962 Views)
Thanks for reply but, some NI engineer said this is impossible.
But they couldn't answer for the reason.
Is this really impossible?
Seong
Message 3 of 8
(4,935 Views)
Hsync and Vsync are known patterns, you want them to acquire images... right? so you have to generate stable and known Hsync and Vsync patterns (supported by your camera). I think you are workng on Winodws OS. so there is a difficulty to generate accurate Hsync and Vsync. so you can check your camera Specification first, understand Hysnc and Vsync diagram and decide whether you are able to generate acurate sync signals or not; if yes then try it once..
Alpesh Prajapati
Message 4 of 8
(4,931 Views)
Hi Alpesh Prajapati
Thanks.
In my system the IMAQ (1410) is well working now in normal connection.
The hsync and Vsync is generated in DAQ and connected to IMAQ through the provided cable (68 pin).
But what I want is to provide the Hsync and Vsync to the IMAQ through the RTSI cable to remove the 68pin cable.
Is this possible?
Seong
Message 5 of 8
(4,928 Views)
Hi Mr. Fah,
Please follow this link for more knowledge (http://zone.ni.com/devzone/cda/epd/p/id/3832)
Master signals and slave signals are the two signal types. The master signal controls one RTSI line, and the slave signals on this RTSI line use the master signal. Each RTSI line can have only one master signal, but multiple slave signals can use the master signal.
* IMAQ Master Signals: Acquisition in Progress, Acquisition Done, HSYNC, VSYNC, Frame Start, Frame Done
* IMAQ Slave Signals: Trigger Start of Acquisition, Trigger Each Buffer
Alpesh Prajapati
Message 6 of 8
(4,923 Views)
Accepted by topic author Mr.Fah
Hi Alpesh Prajapati
I think the example says that IMAQ can generate the Hsync and Vsync but cannot receive them through RTSI
I want to receive the Hsync and Vsync throuth RTSI in IMAQ.
Do you think this is possible?
Please give me your idea.
Seong
Message 7 of 8
(4,891 Views)
The IMAQ boards are capable of sending the HSYNC and VSYNC signals over RTSI, but not receiving them. This is due to the hardware design.
Thank you,
HyunJin Jo
NIK AE
Message 8 of 8
(4,866 Views)
