Hi. I'm looking at the PXI chasis as my DAQ interface. I need to connect a consumer camcorder (via Firewire IEEe 1394). Are any outside vendors that have a card compatible w/ NI hardware and LabVIEW?
MindReady (www.mindready.com) sells a PXI 1394 board. I've never used it, but I've heard that it works with LabVIEW. They are also an NI Alliance Member.
Good luck. Please let the rest of us know if this is a good solution.
