Machine Vision
Recommended Laptop for GigE Vision camera demanding application
I intend to run CPU-demanding labview application on a laptop computer. This application is based on GigE-Vision full compliance Dalsa line scan camera, at rates of ~70MByte/s.
NI recommends Intel pro/1000 Network Interface Card, but I couldn't find Laptop with this card. Also, I don't want the CPU to be loaded by the GigE communication, since it slowdown the VI.
  1. I will appreciate recommendation on the right laptop for this mission (Lenovo is preferred).
  2. If someone had related experience, I will be happy to hear about it.
Gil
(5,092 Views)
In Lenovo, you can go for Thinkpad series. X300 has PRO/1000 NIC and some other models have also. but i suggest you to ask your lenovo dealers before purchase.
Alpesh Prajapati
(5,078 Views)
Can you give us the results of your research ?
Is the Lenovo X300 working at 70MB/s with 1 or 2 Gige cameras ?
Thanks.
Eric.
(4,821 Views)
I haven't tested it with another Lenovo laptop.
Gil
(4,817 Views)
Do you have any reference of a laptot with integrated NIC with Gigabit that works with Gige Vision ?
Eric.
(4,813 Views)
Hi Eric,
Well, GigE cameras will work, but tend to miss data while setting to high data rates.
I estimate that your NIC need to be equipped with Intel Gigabit Ethernet Controller (chip), that support jumbo frames (9014Bytes), and TCP Segmentation.
Intel 82574 controller seems suitable, but I couldn't find a Lenovo laptop that using it.
There might be laptops from other vendors that do use it.
Gil
(4,797 Views)
