Machine Vision
Removal of shadow in an image
I am taking images of coins for my project.
I am in need of removing shadows in the image.
Please guide me a proper way to do it...
-$hiv@
(4,475 Views)
Hi avihs,
The best way to remove the shadows in an image is go for uniform lighting. As for as vision application concern lighting is very much important. We can conclude that  Lighting is inversely proportional to development time.
Silver_Shaper | CLD
(4,467 Views)
I am trying to detect a coin...
Suggest me the best possible lighting setup for it.....
-$hiv@
(4,463 Views)
If you want to see the front of the coin, a ring light is probably your best bet.  If shape is all that matters, a back light would work well, but it is more difficult because you need a way to support the coin without blocking the light.
Bruce
Bruce Ammons
Ammons Engineering
(4,461 Views)
I accept the same. Try to play around with this light. Also consider the Dome Light (Indirct Lighting) incase if you want to get the coins printed features.
Silver_Shaper | CLD
(4,459 Views)
Ok ...i will try n say the result
-$hiv@
(4,452 Views)
