Machine Vision
Required NI Hardware, NI software, Developed software changes : 3 Cameralink camera replaced with 3 GIGE cameras
Current software is working on 3 cameralink cameras connected with PCI1428 and using Labview 7.0 and Vision development module 7.0.
If 3 Prosilica GC650 GIGE cameras are to be replaced with the cameralink camera, what are the changes needed in the NI hardware and NI software and in the software developed in Labview 7.0, without sacrificing the speed of the cameras (90 frames/sec) and PC performance.
(3,338 Views)
Based on  your description above, I'm not clear as to whether you are replacing GigE cameras with cameralink ones or the other way around. Can you clarify?
-Zach
(3,310 Views)
