Machine Vision
Roper Scientific CCD Camera with PXI-1422?
How does one use a Cascade 512B CCD Camera (http://www.photomet.com/cascade.html) with the PXI-1422? The camera outputs its digital signal via DFP (DVI). I've been told that the SCB-100 is needed to interface the devices, but have no info on the sort of wiring required. The 1422 data sheet (p2 camera cables - http://www.ni.com/pdf/products/us/3vis598-601.pdf) also indicates that dedicated cables are available for Roper Cameras, but I was unable to find these on the web site, or any other reference to Roper Scientific cameras for that matter.
Any help/comments are most appreciated.
David Carberry
(3,108 Views)
National Instruments sells some custom cables which will connect between a 1422/1424 and certain cameras. A list can be found in the accessories section of http://sine.ni.com/nips/cds/view/p/lang/en/nid/12067. If there is not a specific cable for your camera, you can use a SCB 100 and breakout the signals. The pinout would be the same as that of your 1422 card. This information can be found on page 4-2 of the 1422 Users Manual, which is located at http://www.ni.com/pdf/manuals/322158c.pdf.
(3,105 Views)
