Machine Vision
Rss Limited is not working
Hi.
I am using VDM 8.5 Evalution version. I want to read RSS Limited Barcode but it is not able to recognize it please help.
Warm Regards
Orooj Ahmed
Message 1 of 12
(5,532 Views)
Hello tpc,
Is it possible for you to attach a few images of the RSS Limited codes you are trying to read?  That way we can work to reproduce the bahavior here at NI.
KyleV
Message 2 of 12
(5,520 Views)
Hi
Please Find the attached file for RSS Limited Code...
We read same code through Atalasoft it is reading and the data is 00614141999996
Warm Regards
Orooj Ahmed
Message 3 of 12
(5,507 Views)
Is the image clarity fine?I feel like the problem is with image clarity and because of that we are not able to resolve the lines?
Message 4 of 12
(5,494 Views)
Double post
Message Edited by muks on 07-17-2008 07:16 AM
Message 5 of 12
(5,493 Views)
Hi
 I have used VDM for other rss limited image to but could not able to read it...
Could you please send us somee RSS Limited Image that can be read through VDM..
Warm Regards
Orooj Ahmed
Message 6 of 12
(5,466 Views)
Hi Orooj,
I tried to run your RSS Barcode with VDM and was unable to pull a string off of it. The Vision Development Package does not contain any RSS Barcodes to read from. You could try the barcodes listed under "C:\Program Files\National Instruments\Vision\Examples\Images\Barcode" but I believe these are EAN 8. Try searching google images for an RSS Barcode and we can try that and see if it works.
Thank You,
Eric Reid
Thank You
Eric Reid
Motion R&D
Message 7 of 12
(5,418 Views)
HI
  I tried with images from google images but not working....please guide me...
Warm Regards
Orooj Ahmed
Message 8 of 12
(5,393 Views)
Hi Oorj,
Can you post a screen shot of your code where you analyze the barcode?
Thank You,
Eric Reid
Thank You
Eric Reid
Motion R&D
Message 9 of 12
(5,366 Views)
Hi
 I have not made any code to read RSS Limited. I was trying to read the Rss Limited code through Vision Development Module Only.
But it is not able to recognixe the code i ahve already sent you the Rss Limited image to which i am trying to read please clear my doubt whether Vision Development Module is supporting RSS Limited  or not
Warm Regards
Orooj Ahmed
Message 10 of 12
(5,290 Views)
