Machine Vision
Run other VI (program) on CVS
I have succesfully run a VI as a standalone application on my CVS and it gave me all the output that I required through VGA port. Next step is I am thinking to add another VI or SubVI to the first VI. I want this SubVI run and stop based on my input selection. Is it possible to give an input (like push button) from the CVS through serial port.?
Farid
(3,675 Views)
I appreciate if someone can answer my above question..  Thanks
Farid
(3,671 Views)
You can pass the input via serial through the serial port, or go the easy route and use one of the general purpose I/Os on the CVS. These are easily accessed via the IMAQ I/O functions that are installed with the NI Vision Acquisition software.
Hope this helps!
-Matt
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(3,654 Views)
Thank you for your answer. I'll try this..
Farid
(3,642 Views)
