Machine Vision
Runing VBAI Inspection from LabVIEW
I found an example named "VBAI from LabVIEW example" (for LabVIEW 2011) that allow to launch VBAI inspection from a LabVIEW application and then get the inspection's results.
The problem that i can't run this example because it used a special library for interaction with VBAI end there is no documentation about this library.
I would like to know who to import inspection name or reference to be executed.
Thank you
(4,967 Views)
Accepted by topic author giusceppe
I found the solution at the example under VBAI 2011/API examples/LabVIEW examples folder.
Thank you everyone
(4,936 Views)
