Machine Vision
Running picture
I'm using a Adimec 4020M/s on a NI 1426 framegrabber, using NI MAX software.
At first I used the camera on a 1k copu 7700 settings, as MAX was set standard to this camera, and it happened to work.
After that I used the Adimec 4020M/s settings I downloaded from NI for 2k, and the picture was clear, but started to vertically run slowly.
Any idea what setting I could change?
Thanks in advance!
(3,486 Views)
Is the size of the picture set identically in max and in your camera setings ?
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(3,446 Views)
Thanks for your reply Dod doc,
It turned out that the setting file for the Adimec camera was not correct. I got a correct one from Adimec, and then it worked fine.
Before I knew there was something wrong with the file, I was able to stop the picture from running by decreasing the pixels from 2048 to 2047. That way I still could do some experiments.
Kind regards,
Harry
(3,440 Views)
