Machine Vision
S-Video display and capture
I am trying to migrate a Labview application from a Mac G3 to an IBM Thinkpad that involves data aquisition and s-video display/capture. The Thinkpad has an s-video input and I have been able to display the desired video using the software that came with the Thinkpad. I also have a DAQCard-AI 16XE-50 that should do the job for the data acquisition and control that I need with Labview.
My question is, can IMAQ vision interface with the s-video input to display and capture images? I would like to be able to display the video signal and upon user input grab a frame for further analysis.
(3,223 Views)
IMAQ Vision will not be able to read directly from the S-Video input, since it is not NI hardware. You will have to find drivers that let you capture an image. It may be a generic input format, such as VFW, that you can find drivers for. Otherwise, you would have to find the driver API and write your own.
Bruce
Bruce Ammons
Ammons Engineering
(3,223 Views)
