Machine Vision
Select VBAI camera from LabVIEW
I have a program in Vision builder AI that acquires an Image and then process it.
I have two USB cameras connected to my laptop and I want to be able to select one of them from a LabVIEW VI.
Is there a way to do this?
Thank you in advance
(2,818 Views)
first check your camera in max if you can open cam in max so you can open it in labview
go to labview help in tools bar select find example in example finder window search for grab or snap there is several example for this reason that could help you
(2,784 Views)
