Machine Vision
Send Image with UDP - Image To Array Problem
hello,
i want to send a color image of my camera with UDP!
i tried to convert the image to an array...but i always get an error: invalide image type...i tried all image types...but no success;/
after that i want to convert the array into 1 string!
i added a screenshot!
any idea?
bye
(3,497 Views)
"IMAQ ImageToArray" does not work with RGB images. The VI "IMAQ ColorImageToArray" supports this image type.
Use the functions "Flatten To String" and "Unflatten From String" to convert the 2D-array to a string - and vice-versa.
Hope this helps, Guenter
(3,483 Views)
hi,
ok thanks, i have to split the string....but much data can i send with udp in 1 packet?
bye
(3,473 Views)
