Machine Vision
Sending a serial command to a camera
I was wondering if it was possible to send a serial command to a line scan camera. I am using Measurement & Automation explorer. How do I go about doing this? I am using the PCIe- 1429 framegrabber. If it is not possible what about Hyper Terminal? Any suggestions on sending a command to a camera I am more than willing to listen!
(3,587 Views)
As I do more searching on this discussion forum I am finding solutions to labview using serial commands. I wonder if it is possible with the explorer?
(3,579 Views)
Doing more research I came across NI Camera File Generator. In this program they have a utility to send/receive camera settings to your camera. The only drawback that may happen is if the response back from the camera exceeds the allowable message length from the software may only show what it can. In other words it may chop off the message if it is too long. I hope this helps anyone who is in a similar situation.
Oh by the way this program I found was in the NI-IMAQ\Utitlity\ folder.  Not sure if it is in every version, but I am sure those who know alot about this stuff can confirm it. Thanks for everyones help!
(3,574 Views)
