Machine Vision
Setting the IMAQ attribute
I was used to adjust the white and black voltage levels (0 to 1.26V) of the NI-1407 to optimize the input signal range of the acquired image.
Now I've installed the NI-1405 and the attributes are different. In particular I can adjust the White level (0.3 to1.26), the Contrast (0.4 to 1.5),
the Brightness (-50 to +50) and the Saturation (0.5 to 1.5). Moreover I see that there is also the possibility to set parameters like the balance of the Red, Green, Blue (gain).
In which way could I adjust the attributes of the NI-1405 to have the same effect of adjusting the white and black levels of the NI-1407?
Thanks a lot
Giancarlo
(3,405 Views)
Hi Giancarlo,
sorry for the very late reply. Take a look to the following docunment:
Black Reference Voltage Level of the PCI-1405 and NI-1411
Hope this helps,
Fabio
Fabio M.
NI
Principal Engineer
(3,363 Views)
