Machine Vision
Setting up a Lord DVL1024R camera with the NI 1426 board
I am trying to get the Lord DVL1024R camera working with the NI 1426 board. The documentation on installing got me as far as starting Measurement & Automation Explorer (MAX), but there was no camera file listed for any Lord cameras.
I tried quite a few of the other camera files that were supplied, but they all failed with various timeout errors.
Searching the net I found a couple of tantalising articles implying that there is support for this camera/board combination, but I have been unable to get any further then this.
Please could you let me know if there is a camera file for this camera or what I should do next to try getting this camera working.
(3,059 Views)
Hi Hawkslade,
I have searched the internet and internally at NI and have unfortunately not been able to locate a camera file for your camera.
My suggestion would be to check out this KB article.
Providing you have detailed specifications for your camera you should be able to use the camera file generator.
Hope this helps,
John
John.P | Certified LabVIEW Architect | NI Alliance Member
(3,030 Views)
