Machine Vision
Simulate GigE Vision Basler Runner Camera ruL2098-10gc
Hi Everyone,
I'd like to know if there is a way to simulate a GigE Vision Camera, I don't have constant access to the hardware as I am working remotely.
It is a Basler Runner LineScan Camera ruL2098-10gc.
Best Regards,
Message 1 of 8
(15,557 Views)
I don't know a way to simulate a camera. Maybe you can save a set of images and work with them when you don't has the camera.
I hope this works for your implementation, please let me know what you think. Best regards.
David P.
www.ni.com/soporte
Message 2 of 8
(15,528 Views)
Hi David,
Thanks for your answer, unfortunately, my point is to work on the implementation of the sinchronization with a line Scan Camera, without access to the hardware, thus I need to simulate this camera to make sure everything works flawlessly.
Best Regards,
Message 3 of 8
(15,522 Views)
I use the racers alot (replacements for runners) there is no native simulated images but I have written my own driver that simulates imaqdx grabs for such situations, this was a decent amount of work.  It is nice to know that I am not the only one that wisthes there was a imaq simulation driver that worked from an image set.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 4 of 8
(15,471 Views)
Hi Paul,
Thanks for your reply
May I ask if you could share your work?
Best Regards,
Message 5 of 8
(15,466 Views)
Unfortunaly this one I cant post.
Essentially I have a simulatoin replacement for Imaq configure and Imaq Grab for simulation.  configure will load the images into memory as an array of imaq images.  The grab handles the timing (line rate x height for linescan cameras)  and returns an image and frame number appropriatly.
Maybe NI will add this to imaqdx in the future allowing for simulated cameras (much like simulated daq devices).
Paul Falkenstein
Message 6 of 8
(15,461 Views)
Hi Paul,
Thanks for the explanation, I hope too that NI will integrate that soon.
Best Regards,
Message 7 of 8
(15,452 Views)
I was looking for the simulator for GigE Camera. Has this been added by NI already you response to this would help a lot
Thank you,
Shiddu
Message 8 of 8
(9,314 Views)
