Machine Vision
Sr. LabVIEW Software Eng.
Hi Machine Vision guys.
I have open position for Sr. LabVIEW Software Eng. that I need to fill up quickly.
What you are going to do is machine vision on LabVIEW FPGA
Job requirements is good knowledge of image / signal processing concept.
Good knowledge of LabVIEW.
Attach is job description.
Position is in Silicon Valley (California)
Amit Shachaf,
Sr. Principal Research Scientist
Nanometrics Inc.
Direct: 408-545-6161
Email: ashachaf@nanometrics.com
Website: www.nanometrics.com
Amit Shachaf
(3,779 Views)
Hi Amit,
You should be posting Job Opening Post in this board:http://forums.ni.com/t5/LabVIEW-Job-Openings/bd-p/JobPost
You can ask Moderator to move the post to specific board.
uday
(3,748 Views)
Thanks Uday
Moderator - Please
Amit Shachaf
(3,739 Views)
I don't think the moderators on these boards can do this.  You'll have to go directly to the board that Uday had mentioned and repost your message.
S G
Certified LabVIEW Architect, Certified TestStand Architect, Certified Professional Instructor
(3,734 Views)
I did repost the massage.
Not much luck ;-(
Thanks - Amit
Amit Shachaf
(3,705 Views)
