Machine Vision
Stopping and resuming a Session is broken?
I am using an NI 1429 card together with an Dalsa IR MCT array. Using the latest IMAQ version, it seems that stopping and restarting a session only work if I use imgSessionAbort and run imgSessionConfigure again. Latter takes really long with a larger number of buffers, hence I dont want to do that. When I just use imgSessionStop and imgSessionStart imgSessionCopy I get junk back from SessionCopyBufferByNumber (I think is the same issue as in https://forums.ni.com/t5/Machine-Vision/imgSessionStopAcquisition/m-p/990516).
So how can I stop and restart my session sucessfully?
(2,884 Views)
Sorry I meant a NI-1427.
(2,833 Views)
Have you tried using IMAQdx? There is full support within that driver now for most functionality that the IMAQ driver provided previously.
(2,800 Views)
I don't belive the card is supported by IMAQdx.
(2,774 Views)
All the current CameraLink boards are supported in IMAQdx since version 18.0.
(2,769 Views)
Oh ok, thanks. Still, imaq-dx needs a ni vision license, which I don't have. Also should I think that IMAQ should still be working right?
(2,755 Views)
