06-07-2006 01:27 AM
06-07-2006 02:41 AM
06-07-2006 12:13 PM
06-07-2006 03:05 PM
Hello Charly.
The version of DirectX is displayed e.g. by dxdiag. You can run the application by simply applying Start>>Run and enter "dxdiag". The tool takes about 10 seconds to check everything, but the version is displayed immediately in the start-up window.
You are right, I am only guessing with my DirectX proposal. I always read this in the release notes of NI Vision but I never took the time to find out what happens when a lower version is installed on the target PC and a NI Vision application tries to playback an AVI (by the means of the DirectShow interface).
"I'm a Macintosh user " - Well-behaved guy -although I have never used a Mac I frequently get impressed when watching Mac users working with it.
Regards, Guenter
06-13-2006 09:43 PM
Bump !
The AVI read back problem is still unsolved. Any advice ?
06-14-2006 12:42 AM
06-15-2006 05:49 PM
06-16-2006 09:02 AM
Guenter,
Thanks for the effort !
So I have now to investigate another tiny track. I'll keep you informed if I get some success.
06-16-2006 02:45 PM
06-16-2006 04:39 PM
Thom's codec issue can be checked with the application "gspot". gspot identifies the codecs required to playback an AVI and it will tell if the selected AVI can be playbacked on the current PC.
You can get it e.g. from http://www.doom9.org/, section "AVI Editing tools".
Regards, Guenter
