01-07-2008 04:37 PM
01-09-2008 04:54 PM
01-10-2008 06:13 AM
Rishee,
Thanks for checking on this. My previous experience had suggested sub-pixel resolution by default, but the system I'm currently working on has surprised me with an unexpected level of noise. Having said that, several characteristics of the new system are less ideal. Most recently, I think I've overcome the 'noise' issue through implementing a simple filter on the measurements I'm taking. For the next week or so I'm on leave, but was under some pressure to prove the system beforehand. At the moment,all looks ok, but I will be doing further commissioning tests from 21/1.
Thanks again for your help. If I have any further problems, I'll look for other causes.
Greg
01-10-2008 08:29 AM
Different algorithms have different sub pixel options and if you want to see what VBAI is using, you can generate LabVIEW code and check out the generated code to see exactly what VBAI uses.
Hope this helps,
Brad
