Machine Vision
Showing results forΒ
Search instead forΒ
Did you mean:Β
Syncing Video and Analog Data on same GUI
I am programming an application that will be monitoring and logging IMAQ video and DAQ Data.  Is there a way to synchornize the data when displaying the post processed data on a viewer GUI?  I'm looking to run the video as if it were live, and have the data displayed on a graph as if we were recording the data from that video.  Will a simple shared timestamp work?
How about Diadem?  I didn't see any support for video files within Diadem...
(4,447 Views)
If the DAQ and IMAQ data are hardware timed, just make sure you timestamp starting points.
If they are software-timed, timestamp every point.
Chris Bolin
LabVIEW Partner Program, CLA
(4,430 Views)
Accepted by topic author eric.atherton
Of course Diadem supports video files πŸ™‚
- Pre-version 10.0: Use DIAdem Clip.  See the Knowledgebase Synchronizing Data With Video In DIAdem Clip.
- Version 10.0 and later:  See the example "Synchronizing Videos and Data"  (located in the DIAdem Example finder under "Viewing and Editing Data")
Chris Bolin
(4,429 Views)
