Machine Vision
The Vision Palette feature does not work..
Hello?
I'm trying to apply a "GeoMetricPatternMatch" with Delphi.
"Invalid GeoMetric Template Image" Error occurs in Function when inputting an image. When I save the Image in "Template Editor", the image format seems to be slightly different.
"Template NG" is a Png image processed by "CWIMAQVision.ExtractColorPlanes", "WriteImageAndVisionInfo" in Delphi program.
"Template OK" is an image saved in "Template Editor".
I think the problem is caused by the Palette Function not working at all. Why can't I change the Palette..?
I installed and tested VAS, VDM LOW Version, and High Version, but the result is the same..
OS: Win10 64Bit Development program: Delphi 7 I use "vision acquisition software 2015", "vision development module 2015" and use Active X.
Message 1 of 1
(1,061 Views)
