Machine Vision
ThermoVision LabVIEW toolkit connection to Flir Exx Series
I am trying to use the ThermoVision LabVIEW Toolkit together with a Flir Exx series camera as part of a closed loop temperature control system, however, there does not seem to be much in terms of tutorials on the toolkit. I am looking to acquire the image from the camera, convert from raw pixels to temperature and using a PID controller change the output of the heater to correct the temperature on the target surface. I was wandering if I could get some guidance on this subject or be pointed in the right direction.
Kind Regards.
(5,037 Views)
Hi Alexisdera,
Have you looked at the User's Manual (http://support.flir.com/DocDownload/Assets/48/English/T559015$a506.pdf)? When you install the toolkit, the examples it describes should be installed to your computer.
If you've already seen this and it doesn't answer your questions I would recommend contacting Flir to ask for assistance, since this is a 3rd party product that NI does not directly support.
Al C
National Instruments,
Application Engineer
(5,007 Views)
