Machine Vision
This chassis has been identified but is not described in the pxisys.ini for this system.
I am using a pxi-1044 chassis through pci- mxi-4 fiber optics. Max shows"This chassis has been identified but is not described in the pxisys.ini for this system."
Please see what I should do with it?
Liming
(3,729 Views)
Hello detech,
There is a relevant KnowledgeBase article that may help you get this problem solved.  KnowledgeBase 459JG8AC: Chassis Not Described in pxisys.ini File gives the steps for resolving the issue that generates this error.
Dan King
(3,704 Views)
Hello All,
The above posted link has changed.  It is now Knowledgebase 4STF48BP: Chassis Not Described in pxisys.ini File.
Paul C.
(3,284 Views)
