Machine Vision
Threshold in VBAI 2009 not working
Hi
I can’t getThreshold function (grayscale) to work properly in VBAI 2009.
I can’tchose “Auto Threshold: Inter Variance”, “Auto Threshold: Metric” or “AutoThreshold: Moments” when I’m in Vision Assistant.
It works if I use the threshold function under <Enhance Images> but not in Vision Assistant.
I tried toreinstall VBAI.
JesperBergvall
Optinova AB
(3,830 Views)
What is the image type that you are using? Can you post the image?
(3,829 Views)
This is a known issue. It will be fixed in an upcoming release early next year. The problem is that a transparent control is covering the bottom three threshold options displayed in the list. A work around for the time being is to select the first item and use the down arrow to select items lower in the list.
Hope this helps,
Brad
(3,821 Views)
Accepted by topic author Åland
Thanks Brad.
I'll work with that work around
(3,816 Views)
