Machine Vision
Time out error message
When I try to send a command to my linear camera, I always get a timeout error message.
The camera is a piranha2 by dalsa and I'm using a PCIe-1429.
I've checked the coniguration file and all I can do is get its parameters but I can't set them.
And when I use the serial write.vi and the serial read.vi, there's always that timeout error.
What should I do?
(3,042 Views)
You will find LabVIEW example and configuration file in linked file.
Isabelle
Ingénieur d'applications
National Instruments France
(3,027 Views)
