Machine Vision
Timeout error trying to grab Redlake ES 1.0 with IMAQ 1422
I have a Redlake ES 1.0 camera and an IMAQ PXI 1422 card. MAX recognizes the presence of the card, the camera is set correctly and all the diagnostics tests pass. But I can't grab a frame in MAX nor open a session in LabView.
Thanks for your help.
Cherie
(3,067 Views)
Hi Cherie,
A couple of things to check at the beginning of troubleshooting include the power to the camera, the connection to the 1422 board, and the camera file in use. Digital cameras like the Redlake ES 1.0 require a particular camera file to be used in Measurement and Austomation Explorer. Additionally, the most recent drivers is always a good thing. You can find our current drivers here. In MAX, check that you are using the correct camera file by right clicking on Channel 0 and choosing "Open camera..." The camera file you want should be shipped with the camera by default and appear in the Program Files-National Instruments-IMAQ-Data folder.
After you've checked these things, I would then try to check the board in a different computer or possibly with a different camera. Let me know how it goes!
Robert
(3,055 Views)
