Machine Vision
Timeout error with external triggering
HI,
               I am using redlake ES2093 camera for capturing TV pattern images using apptern generator. I am using the vsync signal(60Hz) output from the pattern generator for triggering the camera.  I have PCI 1428 card for camera.I have done following settings in the MAX
           Output format   = Single Tap
           Trigger Source = External BNC (since I am applying the VsYNC signal to camera head as triggersource)
           Trigger Mode    = Edge controlled
           Integration time = 16 ms.
           Gain                   = 1db
When I Click the grab option I can see images.
Now I have few questions here. If I am getting images in both snap and grab with these settings, does this mean my caemra is triggered??
If NO what should I do to check that.
If YES, When I change the intgeration time above the 16 ms I get timeout error. I tried increasing  the frame timeout. but it's not working.
Help Me.
(3,783 Views)
The fact that you see a timeout confirms that you are in triggered mode. As an easy test, just disconnect the trigger line and see if you get a timeout.
Since you are using a 60 Hz VSYNC signal, your camera gets a trigger every (1000 ms/60) 16.666 ms. So when your integration time becomes longer, you get a timeout as you miss the next trigger pulse. Dont increase the integration time unless, you see a bad image and certainly keep it under 16 ms.
Hope this helps.
(3,732 Views)
Mr. Yashpal,
Is your problem solved? Do let us know if you have any other issues.
Gaurav
(3,640 Views)
